switch for the PS speed signal function. When I get a moment, I'll install one and run a new wire to the PS controller. I don't know if it matters too much, however Nissan did use the clutch pedal as a vehicle speed signal.
I forgot to mention as well that the neutral switch is supposedly used to activate the "high gear" map in the z32 ecu. Another reason to connect the neutral switch during your MT swap.
